Help me edit this pic
1 Mar 2003
Cotham, Bristol
Ok so it's not brilliant, but I can't exactly go back to re-take it, so guys this is open to edit. Do what you will :)
I had a go. Unfortunately because the horizon is so wonky once that's been corrected the composition of the photo is ruined as the mountain top has to be removed.
Also the heavy compression on the original leaves the photo looking not particularly nice.
Ive also had a go, but had the same problems
^^^ His is better tho.
i rebuilt the missing bits. I dont like the brightness too much now i look at it more, and the blue sky looks turqoise, but i cant seem to adjust it.
Made quite a few changes, didn't think the foreground itnerest was enough to keep so i got rid of that, changed the *VERY* squanky horizon (:p), cloned out the tiny islands in there.
Here's a quick attempt, the colours aren't right, but it's faily simple to keep the mountain top :)
