help me embed pdf into xls or doc
4 Apr 2003
Manchester
I want to hyperlink from a xls sheet or doc to pdf files.
However, this is for distribution and I only want to email one file. Is this possible?
for reference
you have to use embedded package objects
insert>object>package
Then file>import and navigate to your file
Then you can change the picture/icon using copy_paste
Then edit>copy package and paste into document.
