help me finally get rid of soundcard, need passthrough/ATMOS to AVR
1 Sep 2010
Bristol, South West
Hey everyone,
I understand the age of the soundcard is long over. I made a post on an (Audiophile) forum and got berated for still using optical for audio (as Dolby Digital Live sounds "dog***t" and my £2k KEF r500 speakers would think I'm an idiot). Honestly I still think 5.1 sounds great using my Asus Xonar DX, but
a) optical can't do high quality audio (FLACs etc) OR 7.1,
b) I'd appreciate the free space (soon to try to fit a 280mm AIO in this HTPC),
c) PCM only sends 2ch audio.
...so IT IS TIME TO EVICT THE XONAR!
So... how the hell do you guys do audio over HMDI (or DP) to AVR?
2025 is this STILL not possible without caveats? I followed 2 guides but just came across issues and want to know how you guys have done it.
**Note - my main concern is for gaming in 7.1... would be nice to have 7.1 for movies too but meh... rarely watch movies on PC**
-Can we not just get PC to process/send an ATMOS bitstream with the ATMOS app to AVR via HDMI?
-Why does a 2nd HDMI output from GPU HAVE to include a video output?
NOTE:
-Not sure I want display to go via AVR passthrough to TV, as my AVR does not (I think) do 4k 120hz or even 60hz, nor HDR+ or VRR. Maybe life would be easier if I simply had an AVR that does all that...
-I'm not interested in usb DAC's, unless that can help passthrough 7.1 audio?
-Deffo not interested in using headphones or PC speakers instead of a +£5000 Hi-Fi.
Thanks in advance all!!
Relevant specs:
GPU - Gigabyte rtx3080 OC (DisplayPort 1.4a x3 and HDMI 2.1 x2)
MOBO - Asus x570-p (has HMDI out)
TV - Philips OLED 55OLED706 (has E-ARC)
AVR - Onkyo sr6012 (has E-ARC via update)
SPEAKERS - All KEF (r500 floorstanders, iq60c centre, egg rears, +r400b sub)
I have the same Asus Xonar DX as you.
The ideal setup would be
Displayport--->Monitor--->Monitor E-ARC out---->AVR
But most monitors don't have E-ARC out. I think the Dell 4K QD-OLED has HDMI E-ARC out. So it should work.
I tried with DP to monitor, and HDMI from PC to AVR but it causes the system to think it's a dual monitor setup, and drops the display output resolution/refresh to what the AVR supports. I wanted HDMI audio to get lossless HD audio from PC to AVR. I was getting HD Audio fine with HDMI to AVR, but the dual display was causing issues, mouse rolling off the first screen onto the "fake AVR screen"
Yes I agree why don't GPU have "HDMI audio out" like my Panasonic BD820, that way use DP for video, and HDMI for audio only.
I'll be using the Asus Xonar DX for a long while, at least until the next build. Using the custom open source drivers.
tbh I'd just get recommend dedicated audio and video streamers, then using the PC for gaming only.
that way you get HD lossless from movies, framerate switching for movies , 24 bit 192khz from a audio streamer via coaxial (or use streamer analogue outputs) Then for games it's just PCM from the Asus Xonar DX.
Also ensure next motherboard upgrade has spdif out...mine doesn't.
This is easy mate
HDMI from GPU to TV
Set TV audio to bitstream passthrough
Set PC audio output to Dolby Atmos
HDMI from TV to AVR
Enjoy uncompressed Atmos :)
enjoy mouse moving off the side
or
enjoy primary output dropping to 1080p
lol
Why on earth would it be 1080p
Mouse won't move off the side when the TV is off and when it's on then you'll be using the TV, not a monitor. This is such a non issue
Because my AVR is 1080p. Even if it was a new model, it doesn't support the same resolution and refresh as PC monitors.
I don't have a TV but because the AVR is seen as a display, Display CP shows two monitors. To get audio HDMI working the fake "second" display had to be enabled.
It was an issue, whatever option I used it just caused problems. the ideal setup would be if GPUs had HDMI Audio out only
Weird, I don't have this issue at all, my avr does not show up as a monitor in Windows, it just play lovely Atmos audio while I get a 4k 120hz image on my TV
or
lol
None of this is true. You did in fact recommend this same method in your first reply to the OP.
To the OP - the best way is to get Atmos is using the method that both Grim5 and hornetstinger mentioned in his first post ie using earc output from the TV/ monitor to your AVR. This is exactly how I have my gaming PC set up and it works just fine.
Try and seperate the two, 1440p 180hz video to a PC monitor, and HDMI audio to the AVR only.
Thats when issue shows itself
Monitors don't have audio outputs.
Sorry hornet replied to this basically in the other thread, will post here for anyone else to see more info:
(in Xonar settings) When I use PCM out via optical I only get 2.1 audio for some reason. I often forget to switch over to PCM when listening to music and tbh rarely notice, but can imagine it's a bad compression yeah. It's difficult to do an A-B comparison because on PCM it ups the volume and bass. I've never once had surround sound from PC to AVR unless I use DD Live :(
The audiophile dudes say optical cant handle much above 320kbps because of limitations of optical and FLACS can be well over 1000kbps. I think my FLACS sound great, but might be inclined to agree with them because I don't think on my setup FLACs sound much better than a good quality MP3. I've also no complaints with audio quality on youtube or downloaded movies etc... Maybe my ears aren't great from all the motorbiking! But yeah, only 5.1.
Yeah I've heard unfortunately you have to have it set to dual display.
If you just duplicate surely you could just set the 2nd feed to AVR as like 800x600 or something? Maybe it wouldn't use too much gpu power?
Myself, I can't even get the audio to go through GPU to my AVR. The AVR gets nothing.
And if try ARC instead: my TV's HDMI source (HDMI 1 for PC) just keeps switching to HDMI 2: my blu ray, fire cube, or whatever is connected to the AVR. Sometimes this kit turns on as soon as I turn easy-link on... which is needed for ARC. Oddly, ARC instead from TV apps (eg netflix) works fine to AVR... I open netflix and AVR switched to "TV audio"... it's like it needs the AVR needs to like automatically switch to "TV audio" which it does when you play something on TV, but with HDMI it doesn't...
My "Nvidia HD audio" does come out of my TV speakers ok though.
This is why my sound card lives on to 2025 haha!
Posted in the other thread, but additionally test PCM 44 & 48khz first, see what your AVR shows, you want that bit perfect. Once that's working then test DD/DTS movies / TV shows, with MPC DD/DTS ticked your AVR should light up when you play those codecs.
Just means you won't get any HD codecs as SPDIF doesn't support that. But you'll get the DTS core at least.
If priority is video playback and HD codecs just buy a amlogic box and put corelec on it.. That will past DTS HD, Dolby HD, Atmos, DTS X. Output HDR10, HLG, proper framerate switching
Cheap and it'll work better than a noisy PC.
It would be amazingly easy for sure.
As mentioned trying to get rid of optical, as this is mainly for 7.1 and games. Currely using AVR's fake 7.1.
Ummmmm.... I only have the TV. Does this setup require you to have a separate monitor? Although I get no audio on my AVR when I go:
GPU HDMI OUT1 > TV
GPU HDMI OUT 2 > AVR
Perhaps my AVR has to be switched to the PCs video signal correctly to actually play back it's audio... which means I don't get the 4k signal going from GPU direct to TV.
@Grim, Like hornet, unfortunately my AVR does not support passthrough of VRR, ALLM, or 4k 120 anyway.
I'll try fiddling around with arc again guys, see if i can figure out what this hdmi switching issue is. Unless I can sort that I'll never be able to set the displays (TV) input source to the PC.
nah priority is gaming and 7.1 (which can't be done with optical). Pretty sure I've seen DTS light up before... not sure how if ive been using DD live though... as you know you can only tick the one box on the Xonar DX...
Noisy PC?!?! Hah, mine is silent for movies my friend, Noctua FTW!
"GPU HDMI OUT1 > TV
GPU HDMI OUT 2 > AVR"
I've not done the dual HDMI out so not sure how it works
"Noisy PC?!?! Hah, mine is silent for movies my friend, Noctua FTW!"
And my media box is 0db. And about 8cmx8cmx3cm haha . And cost about £40. And uses a few watts. And it passes DTS, DD HD, DTS HD, DTS X, Dolby Vision, HLG. Does a PC do that?
Checkout some amlogic boxes. HTPC are old hat.
Update - got audio out with the 2nd hdmi from gpu (had to adjust amps setup... Im an idiot) and set "turn off audio" in the nvidia app on the TV and turned on audio only (audio out) to the one to AVR... maybe missed that before if it helps anyone else: under sound settings in nvidia CP.
Question - Does having a 2nd display mirrored in the background (looks like its in 4k) use much of the GPU power? Have to mirror it otherwise like hornets said the mouse goes off the screen as it thinks theres two.
Also question... It sounds horrible, likely because no EQ set... any recommendations of a custom EQ app like the asus xonar one?
Will test 7.1 later, must go to work :( Thanks for help guys
Does your TV not have eARC? That way you can use Grim5’s suggestion and have one HDMI cable from the GPU to carry sound and video, with the TV outputting the sound to the AVR over eARC.
To answer your question, if you're mirroring the display then the 2nd display will match the resolution of the main display ie mirror it. GPU power will be used to display this second display. If you can cope with the annoyance of losing your mouse cursor now and again, then it's best to not mirror the display and set the second display to the lowest resolution you can.
It does however I had a LOT of issues before with some sort of hdmi switching issue.
Ironically the Onkyo AVR this Marantz replaced, people did complain about HDMI switching issues!
It's like when "Easy-Link" is switched to On, I think even with "Easy Link Auto Arc" off, the TV wants to keep switching its source from the PC (HDMI1) to the fire cube display or blu ray (which are plugged into the AVR, HDMI4) again and again and again. I have to force the TV to the PC one maybe about 10-15 times before it eventually stays on the PC. I've never figured out how to turn the FireCube Off.
I'll have to see which TV port is E-ARC, I only got one via a firmware update I think, so don't think it's written on the back of TV, 100% was the case for AVR but guess thats just "HDMI out".
I'll have a play later (maybe unplug the FireCube) but will try sort this HDMI from GPU to AVR way first and will compare and contrast the quality after. I hope it works as yeah multiple displays is not ideal... options i get are:
Duplicate - Works OK, but a struggling rtx3080 sending TWO x 4k images? Is my AVR eating watts and FPS gonna be hit?
Extend - Lose the mouse.
Show only on 1 - AVR gets no audio.
Show only on 2 - Bad idea lol.
It sounds god awful atm... Well not awful, treble and bass is clear but somehow it's like all the life/character has been sucked out of the music; particularly in the vocals; likely a very flat EQ. Annoyingly this Marantz seems to apply the bass/treble affects to all HDMI inputs so can't have e.g one for "HTPC" (old asus one) and one for "Marantz" to compare contrast but I'll want custom EQ anyway, who doesn't? I assume you both use one on windows? :D
#i'm tempted to test it fps before and after, but yeah I'll wager at 4k its gonna waste some serious wattage on either the gpu, AVR, or both.
Will run some Tomb Raider benchmarks, one with like 800x 600 or something
I’m struggling to understand your setup. You say your previous Onkyo AVR had switching issues so you’ve replaced it with a Marantz AVR which I’m assuming doesn’t?
I don’t use an EQ on my PC and my soundbar doesn’t have one. All good here. You have set up the sound output correctly in Windows? When I used Windows, it was forever changing the sound setting from Atmos to 2.0
I don't use any EQ, sounds great.
Although for "EQ" that differs to AVR /subwoofer room correction, or using DSU/DTS X sound expansion I don't use any party or disco modes.
PC to AVR should sound good, if you are using DD Live it will be converting CD audio to Dolby Digital. So no wonder it'll sound crap.
Do as I suggested, set output in Asus CP to PCM, 100% output. I think Windows 11 mixer is bit perfect now, but if you use foobar 32 bit then install the wsapi plugin, change the sound output in foobar to wsapi (exclusive) then test 44.1khz and 48khz flac audio.
Then set DD/DTS in MPC HC. You'll get the standard DD/DTS 5.1 mixes. You won't get any 7.1 or greater, or DTS X/Atmos/HD codecs
If that is your priority just get a amlogic media box for your movies and TV shows those will do multi channel bitstream HD.
