Help me find a cutting blade
3 Jun 2012
Hey
Im at a stage of my Robot lawnmower building that i need to get it a safer blade than a chunk of metal that spins
Does anyone have any idea of a better cutting item?
I have seen some plastic discs with plastic blades that stick out that i might be able to use, But they aren't the most ideal.
Anyone got any idea?
You usually have to angle a strimmer for it to cut, but i guess it could work.
Thats ok, I can angle it by lowering the third wheel.
Might reduce energy usage too if you aren't spinning a large weight, although perhaps this is offset by the higher rpm?
The RPM is quite high on this motor, though i am not sure on the torque... A metal Blade seems to work ok as it takes some force to stop it, but thats an issue for safety :/
two words: LASERS
How is "Lasers" two words? and NO
Thinking about it the strimmer idea may work, there may be a number of problems though...
- The line breaks, strimmers have that feature where you can bump the hub on the floor and it feeds some more line from a spool. It could be tricky to modify or implement on a mower.
- The line has memory and tries to coil back, on a short length like a strimmer it's not a big deal but a mower with a longer length it may cause tangling issues or flail about under the mower.
You may want something stiffer and straighter :p;) Probably something that won't shatter too. I was thinking of something like a thin braided stainless wire/cable.
something to think about and experiment with anyway :)
Perhaps you should consider implementing such a cut out. It's better for the system to switch itself off than to wait for someone to shine IR at it if something goes wrong.
I might have a old strimmer head in the van ill have a look tomorrow. I know it's a bit battered but at least you can get a idea from that if you want it?
Thanks for all the sugestions.
I will look into implimenting a upturned cutoff device, it needs one.
The strimmer hubs.. how wide are they and how deep? I dont have much height to play with as it's a small device.
A thin metal wire may work if I can get the rpm up, will look into it.
Im useing a meccano motor at the moment, you might think they are weak but they can drill a hole in thick mdf with a drill attachment ;)
Money is tight so a new motor may not be on the cards just yet.
Ta peeps
/thread :D
They are quite big, which is why you'd need to angle it if using one, or the hub would be dragging along the grass and catching in dips etc.
I think a plastic hover mower type blade would be better.
