Help Me Find A Keyboard Please
12 Mar 2005
My daughter is after a backlit keyboard for Christmas as she's seen a video of one that does a sort of ripple effect with the light from each key as it's pressed.
Does anyone know of a keyboard that does this before I go buying some random one only to find out you can't set up the lighting that way?
Not looking to spend a fortune so the cheaper the better.
A Havit ‎HV-KB432L mechanical keyboard will do exactly what you're after, and at a sensible price.
I have one as a spare, and it's pretty good.
If you google for something like "rgb keyboard actuation ripple" that should give you a reasonable number of keyboards to look over and plenty of videos you can check out to see the effect in action.
