Help me find a replacement AGP card
30 Sep 2003
Norwich
Hi all, I'm in need of some help. I've been out of the PC game for a LONG time but I now need to give my PC a little boost.
Basically I want to make LFS look a bit prettier on my system.
Current specs are- Barton 2500 (clocked to 3200 speed), 1GB Geil PC3200, Asus A7N8X Deluxe mobo and ATi 9800SE which won't softmod due to damaged pipelines.
Basically looking to spend £80 max (less is good ;) ) all in to replace the 9800SE. New or second hand is fine.
LFS is all I play on my pc, but maybe will try R-Factor at some point.
Any help appreciated.
X800's are a good choice as well. Also see if you can find a cheap 6800gs which is another decent card. There's also the 6800 (le?) that unlocks as well.
I'm a bit wary of unlocking cards after buying my 9800SE, choosing the one with the highest unlock success rate... then finding I had damaged pipelines :o :(
Would an LE be a decent upgrade anyway even if it didn't unlock?
