Help me find a shower screen
Caporegime
25 Jul 2003
FR+UK
Hi folks,
I specifically need a folding shower screen with a chrome (ideally) fixing bar, where the fixings go sideways into the wall, rather than it attaching and coming out perpendicularly.
Sort of like this:
if you picture the black line being the wall and the silver line being the fixing bar. Thus far I've only been able to find ones that fix in a straight through fashion.
why would a normal one not work. does your shower not have any end walls? I can't picture a situation where the way of fixing would be used, as presumably your shower is on the silver side of the wall with the door opening perpendicular?! (along the wall?)
can you draw a plan?
Yeah I didn't think that picture was very helpful, this one might be. Fear the paint skillz!
So this is a top down "view":
Red lines = walls and door.
black lines = bath
blue line = screen support and screen
green = fittings direction desired
(obviously I fitted the bath slightly better than my paint skills would have you believe)
The bath is tiled in to the corner and so I don't want the screen covering the alcove because water will inevitably get down behind it and it'll be a nightmare to clean. Also want to put some shelves up in that corner.
