Help me find a small light bulb....
22 Aug 2010
On the Wagon-East Angular
I have a very nice light "thing" in my living room, and it uses teeny, tiny bulbs. Any idea as to what they are called so I can order some new ones?
They are incandescent, are very small and have a tiny thread. Help would be gratefully received! Thanks!!
E10 Miniature Screw Base Bulb ?
The bulb looks older than that ruler, try an imperial measurement search.
Post a picture of the light and particularly the socket that the lamp screws into. Are there any markings on either the lamp or the socket? Sometimes the markings are very faint on the glass, or even a code stamped on the threaded part, again could be small or very faint.
Does the light fitting have a code? Where did you buy it, is it foreign manufacture?
Give us something to work with!
