Help me find a smaller case
16 Mar 2012
Newcastle
I need a little help finding a smaller case for my brother. It doesn't have to be the smallest out there as it's currently all packed into a Thermaltake Level 10 GT so i'm sure that are some out thee a fair bit smaller by comparison but still fit what needs to fit.
He bought it from a friend and I believe it was built by cyberpower and needs to fit the following;
- Asus Sabertooth X79
- 780ti SLI - not sure which card but can find out
- 240mm rad and cyberpower reservoir which I think uses 2 of the bays on the front of the thermaltake.
That's pretty much it other than an SSD and HDD - it does have a DVD drive but not the end of the world if we have to omit.
Nothing garish, small enough to fit under a desk, good airflow and if we can he'd like a window! Plan is to sell the spaceship to fund the new case. But ~60-80 as a rough guide. Also happy to buy 2nd hand.
Cheers
Dan
