Help me find the name of these parts!
Man of Honour
5 Jun 2003
Falling...
I'm trying to find the following but I'm struggling to put my finger on what it is called and I haven't got the opportunity to go to hardware store today.
So I have a couple of bolt/screw heads protruding from where they are bolted/screwed into, and I want to hang or slot something onto them using those bolt/screw heads.
I cannot for the life of me think of what the "bit" is called that would slot onto those heads.
I don't mind if they are adhesive or not.
As an example of what I'm after is similar to what we have on routers/equipment so that you can mount them:
I want to find something like the above that I can either stick onto, or mount onto a piece of equipment that doesn't have slots like the above, but the screws/bolts are already there and might as well use them.
Cheers!
Could try Here
Not exactly what you're looking for but they might have something...
If you don't get sorted send me a message and I'll have a look in our w/shop to see if we have something...I know I have a keyhole punch somewhere.
