I have a full nickel Ek cpu block, a copper and plexi R9 290 aquacomputer block, D5 pump, Xspc 360mm Rx360 V2, Xspc 240mm rad
I have nothing else yet so need all fittings, hard tubing, a reservoir, liquid and other bits and bobs.
Would like to get this project finished, wanting to get something to hide the copper on the block to help it match the colour scheme, which is blue black and silver.
What can i do with the gpu block to help it match and what is the best way to finish this build off?
Cheers
Cheers
