- 20 Oct 2002
- Glasgow
[now resolved - thanks for your 2p's worths
Hi peeps,
I was asked to fix a PC by a friend who presumed that his graphics card was dead. I tested his card in my own computer and it was fine. Anyway, the computer in question is a Fujitsu scaleop with a 3ghz p4 (celeron LGA 775) processor - 630 SL7Z9 Phillipines. The motherboard seems to be a custom one for this system based on the Asus P5SD series - P5SD1-FM2/S
HDD, DVD-ROM, extra network card, gfx all tested ok on my system.
PSU seems to be ok, in that it powers up the CPU fan, case fan, case lights, HDD starts up, DVD opens/closes etc.
After talking with him it seems that the computer was kept in a poorly ventilated corner under his desk where it doubled up as a footrest while it was on
- and he had to replace his old CPU because it died (I presume from overheating).
The components were all covered in dust, and the CPU fan and heatsink fins were quite furry, so I've cleaned up the whole inside of the case, removed and replaced CMOS battery.
There is currently no POST beep and no error beeps, the components are clean.
Nothing changes when I try swapping around or using singly the RAM sticks.
Am I most likely thinking to replace the CPU? Or would you say motherboard is more likely?
Stopwatch starting ... now!
EDIT: Should have said, I don't have a socket 775 mobo or 775 processor to swap either of these out with for testing, so I'd have to go buy it and I'd rather not have to buy both.
Hi peeps,
