help me fix document.xml within word 2016 docx document!!!!
29 Jul 2003
hi
got a document that wont opening anymore :(
i changed the extension to zip, extracted, open the document.xml with notepad++ editor
deleted the line 10, saved, replaced document.xml then changed the extension back to docx. got same error problem but different line. repeated few times
then i got a error message something like premature end of tag something ( i didnt capture a screenshot)
HELP!
thanks
wes
edit: i know what is the problem but i dont know how to fix it as i dont know XML language so ive no idea how to fix :(
You could try an xml validator online maybe?
Copy all the XML, validate it, repair it and paste it back in?
Probably missing a closing tag somewhere, try what AHarvey suggests and run it through an xml validator.
hi
thanks guys!
i tried the the xml online validator, it found error but doesnt fix. what am i suppose to do?
thanks
