Hi all,
First up, i'm still a bit of a noob regarding Overclocking. So forgive me if this seems a bit basic.
So i've had one of the OC'ed bundles from OcUK since October '09, Spec in sig.
Been running at 4Ghz perfectly stable since then. But now i'd like to try and hit 4.2Ghz if i can....
I tried upping the BLCK to 200 and it ran fine for a while then randomly locked up on the desktop.
I upped the Vcore a notch or two it ran the heaven benchmark a few times and locked up again. It also BSOD'ed with a Machine_Check_exception error too.
At that point i decided to put it back and leave it.
Could it be i need to adjust the ram timings or something?
Heres what CPU Z says at the mo....
Any help would be great.
Thanks.
Thanks.
So go and see what you can get out of your system safely.
