help me get more out of this
7 Jun 2003
Gloucestershire
im downloading 3 things via the use of torrents, using the client utorrent, if i have one torrent active it downloads at around 25kb which is crap basicly, if i enable the other 2 as well then the max between all 3 is still 25-30kb, my nets connected at 2784kbps and regular downloads off of websites etc go at over 100kb
anyone have any ideas whats stopping this? im not 100% sure ive forwarded whatever ports i need properly though, my modems a zoom adsl x4 modem (model: 5551) theres a lot of settings in this modem i still dont understand what they do or what they should be set to either so any advice there would be appreciated too
cheers
Cap your upload speed to 6kb/s (capping to 5kb/s automatically caps the download speed to 30kb/s)
This *should* improve your speeds.
As for port forwarding, if your modem/router is uPnP enabled, then utorrent will automatically open and forward the desired port needed.
