I personally think white led would be better for fans mate, too much red overpowers a nice build. White led's will light it up better rather than a red glow. Consider some White cables too, can work well as for some contrast
Your build is essentially an up to date version of mine so have a look at my pc for idea on colours that you may or may not think work well.
image below.
I wouldnt get led fans personally, led strips work better.
Cable wise, 24pin, 8pin eps, and 2x6pin pcie I think for a reference 670 I think but it may be different on the asus.
colour wise red does work well, bitfenix also do red and black cables but they may look a bit too dennis the menace. red, white or black cables would work well and black also helps hide cables a bit.
The enermax fans give off a nice white glow, I had one before and it was a decent fan but didnt shift much air really and the motherboard wouldnt power it properly, kept stalling. I would stick to one type of fan for the case so if you like the sp120's then perhaps get them for the front but the AF versions.
Corsair do 2 types of fans, SP= Static Pressure for high restriction scenarios such as heatsinks,radiators etc and the AF= Air Flow for areas where higher airflow is needed such as case fans. Noy a lot of difference between them really but just though you should know.
Cant see what led's you have spec'd in the build? Akasa have decent strips as do bitfenix but they are a little more pricey.
This should be what you need
YOUR BASKET
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
2 x BitFenix Alchemy 6pin PCI-E extension 45cm - Red £6.49 (£12.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
Total : £27.96 (includes shipping : FREE).
you can do the rest of the components but the cables wont be see so will be a waste of money and be a pain to tidy as the cables get really long with extensions.
The bundle is cheaper though but you will need an extra 6pin as it comes with 1x8 and 1x6 unless you ring ocuk and see if they can make an amendment
only if you do a good job![]()
fans use a 3pin or a 4pin if a pwm fan and can be connected to the motherboard to control them or used on a fan controller which will use a molex
