help me...hazro hz27wc
14 Oct 2011
hello guys,
I'm Italian.
I'm sorry but I do not speak English. I use the google translator.
I bought a monitor Hazro and yesterday came to my house.
But I have a problem.
When I connect the monitor to power the red light comes on stand-by.
when I turn the screen lights up for a second and then turns off immediately. the light turns blue and flashes.
This is normal?
I have already opened an RMA with overclockers, but I wanted to be sure not to miss something.
Thanks to all
paschal
Did you put the DVI cable in when they computer was running? I had the same problem when i started it the first time, it refused to get any connection with the computer. But i turned everything off, switched the DVI-cable around, and turned everything on, worked great.
And are you using the DVI-cable you got with the monitor? What graphic card are you using?
Google Translated for you.
Hai messo il cavo DVI a quando computer era in esecuzione? Ho avuto lo stesso problema quando ho iniziato la prima volta, si è rifiutata di prendere qualsiasi connessione con il computer. Ma ho girato tutto spento, acceso il cavo DVI-in giro, e messo tutto su, lavorano alla grande.
E stai usando il cavo DVI-avete ottenuto con il monitor? Che scheda grafica stai usando?
Thank you all for the help!
I connected the monitor to electrical current. without connecting it to the pc and does not turn on;
when the lights turn on the backlight for a moment and then turns off. do not see any writing on the screen of "no video signal".
Then connect the PC via HDMI (with adapter dvi-hdmi) and nothing changes.
Tomorrow I try to connect with a PC that has DVI-D output with the included cable (dual-link).
Let me ask you:
If you turn on the monitor without connecting it to PC, there is some message on the screen, or will remain off with the blue light flashing?
thanks
PS
my graphic card is ati 4650hd mobile
