Hi, I'm in need of some help. I seem to have hit a brick wall and I'm stuck at 2.85Ghz. So close to getting 3Ghz! I can boot into Windows at 2.9Ghz as well. It's taunting me. Lol.
So, here's what's what.
Multi - x10
FSB - 285
HTT - x3
So this is my current 2.85Ghz overclock, which is running stable with 1.45v (1.41v BIOS).
I've upped chipset and LDT voltages by 0.1v (one notch) to aid stability.
My RAM is on a divider and running underclocked to rule out any issues of stability relating to itself.
So, during my testing I even put the RAM on to 2T command rate to help even more and started to up the FSB.
With 290x10 I can boot into Windows, but Orthos crashes after 10s on the CPU stress test. I have upped the voltage in steps to 1.5v then 1.55v and then even 1.60v. All of which still cause Orthos to fail at roughly 10 - 16s.
Am I doing something wrong, or is the chip at it's max basically? I've ran Memtest to triple check the memory is defo not causing problems, which it can't be imo saying it's underclocked at running at 2T.
Is it just the CPU? I can't believe going from 1.45v -> 1.6v has made no difference. Is Orthos just being stupid? Could I use another application to stress the cores?
Cheers for any help!
Multi - x10
FSB - 285
HTT - x3
I had early X2 3800+ that would'nt even do 2.3Ghz stably no matter the vcore. I think the best i ever got from one was 2.6Ghz ish before i went to Opty 165s.
I don't get this like. Lol. It's like someone dangling a carrott in front of my face and I'm a donkey. LOL!
