Help me Identify Part number? (Seat Altea Instrument Cluster)
6 Jan 2009
Hertfordshire
Good afternoon your helpful lot.
I am in the crappy situation to find or buy second hand instrument cluster for our car (2007 Seat Altea 1.9).
I have the cluster out and the sticker on the back looks like this:
Long story short, cluster is dead, repair company for clusers cant repair it so now i need a replacement which i can then get the garage to re-code etc.
Although they wont take the responsibility of sourcing the cluster
HELP.
Quite possibly yes. I went off the A2C part number on yours but can't see it on that ebay listing... Might be worth checking that with the seller however if you car matches the criteria on the eBay listing it's worth a go.
Yeah i think it does.
Ill message the seller, my car is listed and it has a moneyback (30 days) worst case. The cost is not a massive issue more so the time without the vehicle, so if i can get the right clocks first time it would be massively helpful to me.
Probably worth noting that the final A character in the part number is typically a revision, so a later letter would probably still work, yet be a newer revision part number.
Ok perfect thanks everyone.
I have a set on order should arrive tomorrow. Hoping they are right if not I'll grab one of the sets above linked by pasty
Thanks everyone
