Help me identify this UPVC bubble gasket
24 Oct 2014
South coast
Bought a sample pack of bubble gaskets off eBay but this doesn't match any of them. Any ideas which it is?
Will others fit the same groove? The hinges are shot on one door so the gap is wider than it should be, so if I can fit a bigger strip it might be more airtight.
Your have to get a tape out or a ruler and measure all the points on it most likely you might not be able to get the same but a close one should be fine as long as the bubble is the same height and the arrow is about the same but with the arrow you can just glue it is its a little loose.
Sorry should say its called a bubble gasket.
www.dgsupplyline.co.uk/category/gaskets-seals/bubble-gaskets/ this place has some but not the same design as yours.
Doesn't bode well for me then, I have a few windows that will need the gasket replacing before winter. Not had time to even look at them yet though.
The JCP hardware sample pack is the one I have :D Close but def not it. I have been through a bunch of sample packs now andthey're all packaging up the 10 most common shapes.
Try a specialist like Mighton Products:
You may even be able to send a sample to them for matching; great company.
