Well I've been poking at my new Intel 805D chip and have overclocked it somewhat but I do have some questions because I don't really know what I'm doing.
I've got the chip running at 3.8 at the moment, and I've managed that with a little bit of increased CPU voltage but how do I tell when it's stable at that speed? Is this where I run Prime95? And if it isn't stable do I just keep upping the CPU voltage at all?
Annother thing I've noticed is when I boot into windows I hear all the bits and stuff loading up, but the screen sticks on the welcome screen for a while, is this due to my Ram? I am using no-name ram in dual channel mode with timings that are most likely looser than something very loose. (4,4,4,12).
It's meant to be 533 stuff, so my aim was to get the chip to run around 4gHz with the ram at default, is this roughly what I'm meant to be aiming for?
And what exactly would higher quality ram do with regards to my overclock, will it help, or will it just add annother performance gain ontop of the CPU?
Thanks in advance,
Sorry bout all the questions so far
Thanks in advance,
