http://i6.photobucket.com/albums/y242/hicric/IMAG0028.jpg
http://i6.photobucket.com/albums/y242/hicric/IMAG0029.jpg
Take a look at those pictures. The graphics card is in the PCI-E slot nice and snug, the little clip thingy at the end has clipped in nicely. But the silver connection end shown in those photos is well off! It won't sit flush with the back of the case so I can't screw it in. It looks like it's sort of bending away but nothing seems to be in it's way - can anyone help? I can provide more photos if needed...
Without being able to screw it in it wobbles a lot in the slot and sags downward a bit when the case is standing up (as it's only being held by the PCI-E slot) which makes me feel very nervous!
My case is a Antec Sonata II Piano Black, mobo is Asus M2NPV-VM Micro ATX (Socket AM2). Everything else in the build has worked but this eludes me.
Thanks for any suggestions you have.
But apart from that I don't know....
I've managed to do a really naff stopgap where I'm using one of those PCI slot blockers to slide along the top and 'prop up' the card, it seems pretty solid.
I don't have any tools to try cutting things and modding the case or anything, I'll just see how it pans out - it's not wobbling any more thanks to me sticking that bit of metal in the way, it works...what more can I ask for? I might try and sort of hammer/dent/bend the back of the case in a bit so I'd have a shot with long screws, I dunno.
The rig is really nice and quiet apart from that.
