Help me make up my mind please
17 Jul 2007
Solihull-Florida
ok guys i cant make my mind up,SO HELP
i like the Lian-li V2000b + and
the Coolermaster Stacker 832
i got a gigabyte P35 DS4 mobo
and i am going air with these coolers from ocuk
Scythe Infinity Heatpipe CPU Cooler (Socket 478/754/939/940/AM2/LGA755)
Thermalright HR-03-PLUS (8800 GTX) VGA Cooler (for my GTS)
but soon i want to go on water when i got the cash
so which one will do the air now and water later ?
i do like the stacker because its got a removable tray which is a good thing.
But i like the disign of the lian-li v2000
is the ocuk V2000b+ a version 2? as seen on lians site?
also how much more does a clear side cost for the lian ?
i love BIG cases and i can spend upto £180 on the case
so which one do you think or is there one i have missed.
is there any good or bad points i should know about them both?
at the mow the stacker is fav..but that lian..looks so mmmm
thanks
deuse
EDIT will the Scythe Infinity fit my mobo ??
i had not thought of that duh..
Stacker 830/832 not easy to fit larger rads to, small and restrictive internally, the older pre-transformer stackers were more suitable for water cooling.
V2000 is a good choice, take a look at Lian Li PC-G70, Silverstone TJ-07, TJ-09, Mountain mods U2-UFO as BIG alternatives.
Thanks Davemac,ocuk have run out of V2000 and dont know when they will
have them back in stock grrr
so i take it the v2000 has more room inside then the 832 ?
i have not got that much cash for a V2100+ wish i had :(
Comparing a full tower against a midi tower, have a look for non-sponsored reviews with pics of a full working PC installed.
