- 24 Oct 2002
- Cork, Ireland
Hi,
I've been running Ubuntu on my laptop for about 2 years and have found it great for my purposes (web browsing, email, a few movies, music etc).
I have been thinking about putting ubuntu onto my desktop pc but I have a few problems that I need to overcome first and I hope that the knowledgeable people on here can help me out.
1) HD playback - I currently run my 32" 1360 x 768 LG flatpanel as my monitor. I use CoreAVC to play back 720p MKV's on my cheapie Geforce 5200 which it does very well. Playback is smooth (as long as I don't attempt 1080p files!) on my AMD64 3200 with 2gb dual channel memory. The issue is that when I attempt 720p playback with ffdshow it is very choppy. I believe that if I were to use ubuntu on this pc then I would only get playback similar to ffdshow. This is a showstopper for me. Is there anything I can do (besides buying new hardware) which will enable playback similar to coreavc permits?
2) Divx and DVD upscaling - I currently upscale my non-hidef movies using a ffdshow setup which uses the high quality Lanzcos filter to upscale to my monitors native resolution. I also use a denoise and sharpen filter. This achieves a very good picture improvement. I have looked to try to find something similar on my ubuntu laptop but I cant figure it out. The closest I have come it using SMPlayer which has a basic "postprocessing" option but it doesnt seem to save the setting and it has to be set for each video.
3) Xbox 360 integration - Is there a way to share video's and music to my xbox in the same way as I can in WMP11.
Any advice would be appreciated.
Thanks
Luke
Thanks
Luke
Is it the CPU usage you're trying to keep low?
