Hi there.
My specs.
Asus p5kc latest bios i presume.
Q6600 not overclocked
gf 5200 pci 128mb(temp card)
4gb 2x2gb kingston ddr2 1066 ram in 800mhz mode cos not sure settings yet.
sb audigy 2 zs
samsung f1 500gb drive bought erm march i think ish
maxtor 200gb ide drive
Righty o.
I turned the comp on it wasnt coming on properly. Heard a creak and it started staying on also i did the hold del while turning the comp on.
So i used load default setup and went to install vista 64bit ultimate ed.
Thing is it was dog slow. Vista was stuck on 1 screen before u do anything for 5-10 mins. This happened on a few places.
Eventually it got installed. But the performance test got stuck about 20% done i left it for 20 mins the bar didnt move, the computer wasnt crashed of frozen as numlock light went on and off when i pressed it. So your guess is as good as mine.
General slowness since.
Now in bios i took speedstep off but its still declocking my cpu. I also tweaked the ram so its 2t command rate, 800mhz, auto settings like 5,5,5, etc.
Here is reading of coretemp just installed it not messed with settings for it either.
The temps are inaccurate i think because i have this sensor for the front of my antec p160w case and its got one of the sensors on the tuniq in the middle under bit of one of the heatpipes and its reading about 28. Also my vid seems high i expect it to be lower.
Here is cpuz and keep in mind speedstep is off in bios.
Here is my ram settings in cpuz.
Also i get little bars poping up sometimes maybe cos of the card i got off mate the 5200 or that its just pants i duno.
Help me cos i want this to be as fast as it should be peeps. What bios settings do i do etc.
My specs.
sb audigy 2 zs
Righty o.
