Help me O/C my 2180 on DS2R Micro ATX
JSW
JSW
19 Oct 2002
Staffs
Havn't done any O/C for a couple of years and finding the bios a little confusing :eek:
Would like to try and get my 2180 to 3Ghz
Spec:
Samsung SH-S203D 20x DVD±RW SATA Dual Layer ReWriter
OCZ StealthXStream 600w Silent SLI Ready ATX2 Power Supply
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB)
Zalman CNPS8700-LED CPU Cooler
Gigabyte GA-G33M-DS2R Micro ATX (Socket 775) PCI-Express DDR2 Motherboard
Western Digital Caviar SE16 250GB SATA-II 16MB Cache
Crucial Ballistix 2gb PC8500 1066mhz
Many thanks
Its ok had a play and 3Ghz was easy enough :)
running orthos at the mo temp 58C
10x300 FSB
Mem 3.33 divider at 1000Mhz
Should I change the divider and run the mem higher ?
Thanks
