Help me O/C my 7970 windforce
17 Jul 2008
Ok i think i'm in need of alittle help. My card has a stock voltage of 1174mv i have had it bench heaven at 1125 core without artifacts on stock volts with memory at stock. Drivers are latest beta and using afterburner 2.2.2 , limits in CCC are 1200 core and 1650 memory. Have the missing dll files in afterburner folder. My card has a small amount of coil wine when testing but as soon as i try to test at 1130-1140 core i get small flashing areas of textures in heaven but it will not crash or freeze. I have had 20%power and also tried alittle extra volts, 1187mv but i get more coil whine and a sort of fizzing noise with it. I haven't tried anyfurther as i don't want to damage my card. I know these are good for at least 1.25-1.3 volts on air and gpuz is telling me my card is not pulling 1.174v at load more like 1.65v which i guess is a little v droop. Temps have been 63° at most during heaven and 30° idle.
Your card will not be pulling 1.65v ;)
Coil whine is a common on these cards, all 3 of mine had it and it's mostly vanish now with them being used, so it should get better - it certainty won't break the card.
Just keep pushing the volts and try a bit more memory volts ( this is in the msi sub menu).
I would try 1.2 volts, and try and keep the temps down as that in my experience is what causes artifacts when overclocking.
Coil whine is a common on these cards, all 3 of mine had it and it's mostly varnish now with them being used, so it should get better - it certainty won't break the card.
Fixed it for ya :D
I didn't get much coil whine on mine I think I get it if I have my fans above 60% which I don't, I have my fan at 50% max.
I think cliff meant 1.165mv. Also I have heard people getting rid of coil whine by leaving heaven running for a few hours or over night. Also with the weather at the moment its not ideal overclocking weather ,you will hit higher temps quicker.
Regards
Yes sorry typo, 1.165v. Lol. Won't try at moment as idle temps are up by 6° in this heat. Thx for advice, don't think these cards like getting hotter than 60° it seems.
All most cards are water cooled and my PC is quiet, I can hear my harddrives (backup) and Don't notice any coil whine any more.
