I have read the sticky and guides before you say read them
OBJ: Overclock CPU, as much as possible
I was told try
FSB 220
CPU 0.15v and ram (raise them) dont know how though
drop ht multiplier to x4 [its at default] (can do this)
Spec:
AMD A64 4000+ 1000cache
Gigabyte GA-K8NXP-SLI
HIS x850 xt pe
Corsair 2gb ddr xms3200c2pt twinX 2x1gb cas2
Thermaltake xaser case x5000 a
Thermaltake Butterfly 480w PSU Black
Software: (They both report my cpu temperature different but when i;m in bios its around 30-37ish - Everest also matches my gpu temperature with ati-tray tools)
Core temp (42c)
Everest (32)c
SP2004 "BLEND TEST"
3D Mark 06
Throttle watch (Dont understand how to use)
I want to overclock my CPU but i have googled around and still cant really find a "SAFE" temperature to be looking for when overclocking
I also have learnt that i need to unlock or reveal a setting in my bios via (ctrl f1) for settings on overclocking
My bios shows these in MB1 tweaker or something
FSB 200 [200+]
Pcie clock 100 [100-150]
k8 cpu clock ratio Default [4-12] [800 - 1200]
Robust graphics booster Auto [fast, turbo]
CPU Voltage Control Normal [0.800V - 1.750]
Normal CPU Vcore "cant edit [1.500]
Core power volt control Normal [+0.1 - +0.3+]
HT link voltage control normal [+0.1 - +0.3]
DDR Voltage control normal [+0.1 - +0.3]
The ctr+f1 Where i unlock stuff i cant remember i can give names if i will need to change stuff in here to overclock
I was told try
FSB 220
Spec:
HIS x850 xt pe
Core temp (42c)
Everest (32)c
SP2004 "BLEND TEST"
3D Mark 06
FSB 200 [200+]
