Help me OC my q6600 & spec me a cooler
14 Oct 2006
looking to oc my q6600 from its stock setting to something a little bit better
im running 8gb of ocz ddr2 & its all sitting nicely on a gigabyte GA-965P-DS3P
also need a cpu cooler, no height restrictions really as long as it aint massive
For something simple, change the FSB to 334, set the multipier to 9, set the PCI-E frequency to 101 and set the memory divider to something that your memory would be comfortable with. That should see you to 3.0Ghz :)
EDIT: Don't forget to Prime for an hour or 2 to check stability and for a cooler, Thermalright Ultra 120A standard or extreme, YOU DECIDE! :)
