set everything to manual and just take it easy. my first overclock was with this board and i found it really easy got my a64 3800+x2 too 2.6ghz on stock cooling . when i get water i rekon i can get 2.7ghz out of it
If your processor is a Venice 3200+, you should be able to see some nice results.
Put a divider on your ram
Up CPU voltages, 1.6MAX
Put ram voltage to 2.8v
put your HTT to 3.0
CPU mutliplier to 9.0
And up FSB in about 5-10 increments.
Also, download Prime95 to benchmark and see if oc is stable!
Well I have just had a go at overclocking on my new Asus A8N-E and nomatter what I change I always get 2.4GHz in Windows, im lost to be honest lol, this is the only board I have been unable to clock with first go.
This is on a 4000+ SD
Lowered HT to 4x
CPU Frequency 220MHz
Multi 12x (Original)
333Mhz Divider
Now this should get me 2.64GHz yes? Then why is it 2.4 on CPUz and in My Comp
