stigggeh said:those look ok to me... vcore is already higher than stock iirc and ram is also on a divider....soooo
just lock the AGP/PCI (66/33 is the option you want) and edge the fsb up
edit 5mhz at a time.... checking for stability each time (occt is usually a good prog for pushing as it only takes 30mins and seems quite sensitive)
when it fails occt bump up the vcore more (dont go past 1.65 cpu-z/MBM5 reading not bios)
then push again... when it fails to go higher back off a little and run SP2004 (the orthos beta) and run for 10hrs plus
wiggyuk said:Ok I have set AGP/PCI to 66/33 what software shall I use to monitor my temps ?
When I start OCCT it asks me what monitoring software am I using, what should I use ?
stigggeh said:for that board i would say MBM5 (motherboard monitor 5)
and yes.... i think its best to always use the bios
Yup what he said! MBM5 v370 for the win!stigggeh said:for that board i would say MBM5 (motherboard monitor 5
wiggyuk said:How do I know which temp is which ?
Would the higher temp be the CPU ?
Also when should I start to worry about temps ?
