Help me pick a case?
16 Feb 2006
My current case uses a bunch of 80mm fans and the noise is just insane.
I'm currently looking at either the antec 900 or the CM 690 II (but sadly not from OcUK as they dont stock the windowed version)
Which do you guys feel is better for noise, cable management and dust?
I can't choose!:D
The Antec 900 has no dust filters, mediocre cable management and its a VERY open case, so noise tends to escape. The 690 II comes with filters, plenty of cable management space and I believe its generally a quieter case. Might need some extra fans though if its for an overclocked rig
Ok well it's done and a windowed cm 960 II has been order from elsewhere
Mega shame OcUK don't stock it, free shipping was badly missed :D
Will I be needing to purchase an 8pin and 24 pin extension cable you reckon ?
yeah i got a few/half a dozen floating about in various places and cases.
Might have to invest in a fan controller as well
