Help me pick a graphics card?
7 Oct 2008
Hey all,
Time for a new graphics card...
I did have a Radeon 4850 512MB Overclocked, which ran pretty well but decided to sell on to a friend and buy another "better" or "equal" card, and i do plan on overclocking the card for more performance...
So far im deciding between:
Palit nVidia GTS 250 1024MB
GeForce 9800GT 1024MB
Sapphire ATi HD 4770 512MB
The card will be paired with the following system:
AMD Phenom 9850 Black Edition
8GB DDR2 800 (4x2GB)
Corsair TX 750 PSU
Which one of these is the best? i hear a lot of good things about the HD 4770 once overclocked, but would the 128bit 512MB of memory be a bottleneck for todays games?
All help appreciated guys...
I wouldn't get either the Nvidia GTS250 or the 9800GT (they are essentially the same card as the 8800GT was). I'd either try to find a cheap ATI 4870, 4890 or a Nvidia GTX260 or GTX275 if I were you. It will be a nice upgrade.
you wont go wrong with a GTX 260, go for the 216 stream processor one though, you can get them for about £130 now, maybe cheaper
im guessing your looking at around £80 to spend on a gc, maybe have a look at the 4850 at exactly £80. either that or look for a second hand on ebay
