Hello..
I cant decide on what one to buy. What one would you buy and why?
My main usage would be general desktop use, watch the odd dvd. Would the ATI gfx on the A100 be any use for games in the past few years? I'm not a gamer but would like to be able to play some games of a few years old. CMR4 for example. I dont really know that much about Core Duo. I am upgrading from an old athlon xp 1.4ghz cpu and an extra 200mhz does'nt seem that much on the A100
The A120 is strengthened, better casing, keyboard etc.. but I dont know how much that matters give it will 80% be used in the home. I will also be using an external 19" Monitor with it if that makes a difference on choice?
Thanks.
Dave
Toshiba Satellite Pro A100
Processor - Intel Core Duo ( T2300) 1660MHz 2048KB (L2 Cache)
Chipset - Intel 945PM Express
PCMCIA Slots - 1 x PC Card Type II
Maximum Bus Speed 667MHz
Hard Disk - 60GB Hard Drive
Optical Drive Type DVD±RW (Dual ±R)
Monitor - 15.4ins TruBrite TFT WXGA 16.7 million Colours
Sound Device - 16-bit Stereo
Speakers - Integrated Harman/Kardon Stereo Speakers
Network Interface Ethernet 10/100/1000Mbps Integrated
RF Network Standard IEEE 802.11a/b/g
Bluetooth - Bluetooth
Data Modes - V.90 (V.92 ready)
Graphics Device ATI Mobility Radeon X1400 DDR Video RAM + DDR2 RAM (system memory)
Video Card Maximum Resolution - 2048 x 1536Pixels
VGA Port - 1 x 15-pin HD D-Sub
TV Out - 1 x NTSC/PAL RCA connector
Headphone Ports - 1
Microphone In Port - 1 x External
RJ-45 Ports - 1 x RJ-45
USB Ports - 4 x USB 2.0 (2 Rear, 2 Right)
IEEE 1394 (Firewire) Port - 1 x iLINK
Toshiba Satellite Pro A120
Manufacturer - Toshiba
Processor - Intel Core Duo ( T2400) 1830MHz 2048KB (L2 Cache)
Memory (Maximum) - 512MB ( 4096MB) 533MHz DDR2 RAM
Hard Disk - 80GB Hard Drive
Optical Drive Type - DVD±RW (Dual ±R)
DVD-ROM Read Speed - 8X
Monitor - 15.4ins TFT WXGA 16.7 million Colours
Sound Device - 24-bit Stereo
Speakers - Integrated Stereo Speakers
Audio Features - MIDI support
Wireless System - Intel PRO/Wireless 3945ABG
Graphics Device - Intel 945GM Express Chipset 128MB DDR2 RAM (UMA)
VGA Port - 1 x External
Keyboard/Mouse Combo Port - 1 x PS/2
Modem Port - 1 x RJ-11
USB Ports - 3 x USB 2.0
DC Power - 1 x DC in
Dimensions - 36.8cm (W) x 26.8cm (D) x 3.69cm (H) - Weight 2.90kg
Number of Card Slots - 1
Secure Digital - Supported: Secure Digital, Secure Digital IO
Thanks.
Dave
Headphone Ports - 1
