hello all
im currently using my nikon 18-70 kit lens that came with my d70 as a walk about lens.
Im after a new general purpose lens. will be using it for a bit of every thing. a new walk about lens. for my d90.
more than likely to use it for landscapes so need one with low barrel distortion at the wide end. The most important factor is IQ and sharpness tho.
i have a maximum budget of £300
the 3 main ones i've come across are the
Sigma 17-70mm f2.8-4.5 HSM Lens.
Sigma 18-50mm f2.8 Macro HSM Lens
Tamron 17-50mm f2.8 XR Di-II LD ASP IF Lens
I like the extra reach of the 17-70 but am a bit put off that its nots 2.8 through the entire range. Also i've heard its not as sharp as the other two lenes???
the tamron 17-50 and sigma 18-50 both get good right ups. the Tamron is 1mm wider, but id go for the sigma if the IQ/sharpness was superior.
I think its between the latter two lenes, unless im wrong about the 17-70???
i just cant decide, need a helping hand.
also if there are other lenses i have over looked within my price range please say.
thanks.
thanks.
