Help me pick a monitor
30 Oct 2016
Hey chaps,
I'm struggling picking a monitor that has all that I want..if there is such a thing! Can anyone suggest a monitor that matches the following specs please?
27Inch
IPS Panel
1440p
144hz
G-Sync
It's a lot to ask but there may be someone out there that can advise me!
Cheers all
Err..
AOC 27" AGON AG271QG G-Sync 165Hz Gaming Monitor
27" Asus PG279Q ROG Swift 165Hz Nvidia GSync
27" Acer XB271HU G-Sync LED Monitor,
Just FYI, IPS panels have lower response times than TN panels, e.g. the AOC monitor mentioned is quoted as having a 4ms response time vs the equivalent TN panel with similar specs which all quote 1ms response time..
What that means is less ghosting/streaking on a TN panel then the equivalent spec'd IPS panel, and IPS also has higher black levels etc..
Got it,
So basically your paying a premium for an IPS panel with a high refresh rate, I may just go for the 27" TN then as I have a 23" IPS that I can use additionally.
Any recommendations for a 1440p 144hz 27" TN in the £250-£400 bracket?
