In that case you will indeed be able to use the Dell U2311H to connect both the PC and a HDMI games console at the same time via digital connections.
The U2311H uses an E-IPS panel that has a range of benefits over the TN panels used by monitors in this price range and below. The main ones are much wider viewing angles (
this video compares the viewing angles of the U2311H's predecessor the 2209WA with a TN samsung), a proper 8 bit panel (unlike the 6 bit + dithering panels used by most TN monitors) and generally better image quality.
Here is an in-depth review that fully explores the U2311H.
As coupe69 mentions, given your budget you also have the option to go in two other cool directions - "3D/120Hz" and "bigger".
The 120Hz option is pretty cool, though these monitors only use TN panels the loss in image quality and viewing angles is offset by high responsiveness and smooth motion (when used with the PC), as well as the ability to play games in 3D (if you invest in the correct glasses and software).
As for "bigger", the extra viewable area offered by a 27.5in monitor is
considerable. Monitors like this still use TN panels and are not as responsive as 120Hz monitors, but they are fast enough for modern games and the extra size certainly helps with immersion.
