I'm looking to buy a tablet but I'm confused by the array of different models availible.
I'm looking to spend around 200 - 250 on it at a maximum.
Main use will be web browsing for forums and the like (i'd would like flash support as several sites I use have flash applets on them), watch iplayer and youtube as well as listen to music.
I'd like as large a screen as possible but not sure if this is going to be viable with my budget?
The ones I've found so far that I've liked have been the Nexus 7, Nook hd+ or the Acer Iconia.
The problem with the Nexus 7 is the lack of a microsd port, the nook doesn't run vanilla android although I couldn't find anything wrong with the acer but I haven't checked any reviews yet.
Can you get a separate keyboard for most tablets if they have bluetooth in them?
Is there anyother tablets that I've missed?
