Hi all,
Ill be moving into a flat within the next month or so.
Here is a proposed layout for surround. Am I right in thinking the surround speakers should actually face in the direction indicated by the crude arrows? Or slightly more angled - honestly that's a non issue anyway.
I suppose my real questions are..
1. If I buy a Nvidea shield and plug say an 8TB drive in, will I be able to map that drive to the network and send files to it from the PC from within windows files explorer?
The shield would be used mostly to playback 4k files along with the soundtrack (I may go atmos but with the speakers that fire up only).
2. I think some gigabit powerline adaptors will be the only realistic way of getting from the router near the TV to the PC? Should be ok right? I can then finally have a proper desk setup for PC only games ie. mouse and keyboard - also I want a little midi controller to use with FL studio just messing around.
I don't have a monitor yet though, I think maybe a 32" 1440p 120hz or something like that should be good. I have never gone above 60fps so wouldn't mind trying that.
3. No here is the toughest problem.... How to get a 4k HDR 60fps signal from the PC back the main TV?
This is where I am coming up short with my plan so far. I wonder if those ethernet to HDMI things would work when combined with powerline adaptors?
Building a seconds PC just for playing on the sofa seems a bit overkill considering I dont game much anyway, I just want the option really.
Any thoughts, ideas or total shift it setup is all welcome!
Just to add - All I have for now is the TV and a 2.0 setup with Dali Zenzor 1s on stands that will be used until I add more/upgrade maybe down the line.
Thanks,
Sean
Thanks,
Sean
