Caporegime
- 7 Apr 2008
- Lorville - Hurston
Hi all.
I am in the process of buying my first home with my partner and its a semi detached 3 bedroom that will need some modernisation done to it.
So as part of the rennovation work, i have a rare chance to go nuts and install whatever network setup i want.
Here is a diagram of how i invision it all being connected up along with the devices that wiill be wired connected.
The arrows represent the network cables that will go behind walls and floorboards.
The ethernet switch and patch panel show just one arrow/network cable but it will obviously have a cable for each device connected to the panel.
The cables i will use will be mainly OM3 fibre cables as i want to future proof my network setup and have 10gbit minimum across the board with the ability to increase the speed in the future.
For POE devices i may run a ethernet cable for those parts but the majority will be fibre.
I plan to have keystone fibre wall sockets as identified in the diagram .
I have a few questions above:
List of potential switches i will use/consider:
I do believe that fibre cables do not support POE so i may need to add a POE box somewhere close to the survailance camera.
Thoughts?
Thanks for taking some time in reading this and i am open to some suggestions and tweaks for my plan.
- If i used a 10gbit switch downstairs connected to the main router, and my upstairs switch uses a 28SFP connection between my linux server and main pc, would the router and downstairs switch cap the speed at only 10gbit? or willi get the full 25gbit transfers between the PC and and linux server upstairs both connected to 2 ports on the upstairs switch that are 28sfp ports?
- What Router do you recommend that has a nice UI with some advanced functionality like VLAN's etc? It also needs to connect up to community fibre internet directly as i do not want to use their supplied router/modem
- Do you guys have any recommendations as to what outdoor survailance camera i can use? My missus ideally wants me to install a wireless one but i am worried about battery life and the signal of transfering and streaming the video feed from outside?
- Mikrotik CRS310-1G-5S-4S+IN (4 SFP+ ports and 5 SFP ports)
- Mikrotik CRS309-1G-8S+ (this one has 8 SFP+ ports
- Mikrotik CRS317-1G-16S+RM (one for downstairs next to router as this has 16 port SFP)
Thoughts?
