- 24 Oct 2002
- Reading
Hi all,
Hoping someone can help me as I'm tearing my hair out failing to get internet in my garage which is 40m or so from the router with a couple of brick walls in the way.
I first tried powerline adaptors as the garage has power (these ones which are a few years old now https://www.bt.com/help/broadband/broadband-extender-500-flex-kit-for-bt-tv) and an access point I connected to the powerline in the garage and it worked fine. Speeds dropped from ~50Mbps to ~14 Mbps but was happy enough with this. The data light changed between green, orange and red randomly suggesting the powerline connection wasn't great.
After a day or so the access point lost connection to the router and after I reset the powerlines it came back up.
The next day my devices I was connecting to the AP couldn't get IP addresses.
I tried another AP (this time an unused BT Smarthub which I put in AP mode). Then had same issues with dodgy connection over the next few days.
Next I tried getting a WIFI extender ( https://www.tp-link.com/uk/home-networking/range-extender/re305/) plugged into the socket in the house nearest to the garage (30m away) but the signal wouldn't stretch through the garage wall
So run out of ideas and wondering if better quality powerline adaptors would make a difference?
Any advice appreciated, thanks
