Help me please!
15 Feb 2011
North Yorkshire
When I switch on my pc, all that happens is I get a message saying 'boot manager is missing press alt cntl del to restart'. Why??? How can I fix this?
Hope someone can help
Cheers
Just checked the manual its DEL to enter the BIOS and F11 to enter the boot menu - so try F11.
(I assume its the motherboard in your sig)
nope still cant get in
Fed up, can my motherboard have failed? its a new one about 2 weeks old!!!! after having 3 Asus ones OKUK fitted this one for me, can i really be that unlucky????
Hmm, what happens when you press F11, have tried constantly pressing F11 during boot until ones finger starts to hurt!!
Could try this:
One option is a CMOS reset, you would loose the overclock unless you have saved it as a profile in the BIOS.
Theres a button along the bottom of the board (by the last pci-e slot) with Reset written on it - push once.
Unplug pc from the wall.
Remove the battery on the motherboard.
Leave for a few seconds
Replace battery.
It is unlikely that a CMOS reset would alter the boot config though unless it had already been altered by the system builder.
Try the CMOS reset by all means and when you have and if you still have no luck try this:
Whichever drive is your boot drive (SSD I presume), remove all other drives SATA cables and just leave the boot drive plugged in. IF windows still will not boot it could well be a corrupt install.
Either way, you really need to get into your BIOS. Stupid question but you sure you're pressing the .del key on your number keypad and not the delete key above 'backspace'?
