Help Me Please!!!!
28 Feb 2011
Norwich
Hello, this is a case/hdd question so to get a quick answer i thought i'd post in general.
I have the bitfenix ronin, i have now got another 280x (tri-x) to go with my toxix so all the lower hard drive bays are being taken out, which means i have to move my hdd to the 5.25 bays
I need an adapter to fit my case so i can put the front cover back on.
all i can find is
http://www.overclockers.co.uk/showproduct.php?prodid=CA-056-BX
but i dont want that front panel, i was to completely seal it off so dust doesnt go in....Help
edit - something like this
http://www.overclock3d.net/gfx/articles/2013/10/14162141869l.JPG
this is the one that came with the case, that holds my ssd. But you can't buy them which is stupid
the more worring part is in your sig...
Coolmaster Silent Pro700
you need a better PSU, 750W is pushing it if your not OC'ing your system and you are so 850W is needed
your psu only as 600w on the 12V and 50Amp
i want a bay that can hold two 3.5 hdd. i was thinking of bolting the ssd to the bottom and suspending the hdd above it
i think i'm going to go with the Seasonic M12II EVO Edition 850W
but im stuck about this bay. I have a 5.25 to 3.5 in at the moment and my ssd is screwed to that. If i could replace that with a 5.25 to 3.5 that held a ssd screwed to the bottom and the ssd ontop. this is confusing
TBF i have no idea i would just google drive bay adapter OcUK dont have what you need.
i my case i have used m3 sticky tabs to mount the SSD to the back of the motherboard tray and the hdd's to the base
haha i was thinking about taping the ssd somewhere with electrical tape and mounting the hdd where the ssd was but i dont know if i'll kill the ssd
