help me plz :)
9 May 2010
sheffield
1) what's the budget?
2) response time doesn't make too much difference providing it's no more than 6ms so 5ms is fine
3) if you want to get the GTX 570, I would suggest getting the 470 instead and getting a better monitor because there isn't too much performance difference between the two and better monitors are definitely worth that little performance decrease
4) dual screen for gaming? bad idea, three screens or one screen is fine but two or four splits the reticle or centre of the image.
not to sure on budget, id like to keep it under 200, ive already settled on the 570, not using dual screens for gaming. but i mite use my current screen as a secondary desktop
