Help me prove this is worthwhile (980ti)
9 May 2006
Nottingham
Hi all my dad doesn't think that getting a new graphics card would be worthwhile for me but I think it will be. I currently have an amd 7970 and an i7 920 at 4 ghz (spec in sig).
I play my games at 2560 x 1440 and I can't max Gta 5 or Arma 3 and I think a 980ti will make things better, especially in gta considering arma is more cpu intensive.
My dad made a good point that upgrading my system to an x99 based one might be more of a benefit.
So who is right?
For gaming, upgrading your gpu will show much more improvement than changing your cpu. Despite its age, the 920 is still pretty good for gaming.
So who is right?
Arma 3 is completely CPU dependant. I had a I7 920 @ 3.8Ghz, upgraded to a 6700k @ 4.7Ghz and it made a huge difference. That game loves high IPC from the CPU.
Thanks for the replies. I think I will drive down to ocuk today and get one, or just do the sensible thing and get it delivered. Impatience is a terrible thing! Am I right in thinking that I need to have the latest motherboard bios for the graphics card to be detected?
I ran an i5 750 with a 980TI for a few months and it was great. It was a much bigger improvement coming from a 7950, than buying a 6600k later.
Some games were a bit CPU limited though, like Far Cry 4.
It depends on the motherboard. My Asus didn't need an update but it exposed an unstable overclock.
I would replace the I7 920 with a Xeon X5650. Six cores should help in ARMA.
I would try that before going X99 any way.
Well I've just updated my bios to the latest version and I have lost my overclock. This wasn't a problem I thought as I had taken pictures of all the settings anyway. But unfortunately my computer doesn't want to boot with the overclock now. :(:(
I am a massive noob with overclocking so is there a really easy way of getting me to at least 3.6 ghz?
Well I have just installed a Zotac 980ti AMP edition into my computer and I am very impressed with it. I'm now reinstalling Windows 10 to make everything cleaner and the all I need to do is work on getting my overclock back to 4ghz.
Thanks for the recommendations for a great card!
good choice mate. enjoy it :cool:
ARMA3 uses a crap engine which is still bottlenecked by a single thread,which is laughable in 2015 when even Bethesda has modified the ancient Creation engine to support upto 6 to 8 threads reasonably well!
To be put in context,an overclocked Pentium G3258 can match overclocked Core i5 CPUs in the game,last time I checked.
