5 Jun 2009 at 21:32 #1 Monkeynut Monkeynut Soldato Joined 7 Nov 2007 Posts 6,858 Location Required Hi. Opteron 175. Stock voltage, OCed by 100mhz to 2.3ghz Arctic Cooling Freezer 64 Pro. Core Temps from core temp when loaded under orthos are: Core 0: 61 Core 1: 51 Lian-Li PC-7 with both fans running at full. Gogogogo!
5 Jun 2009 at 21:51 #2 user1453 user1453 Associate Joined 18 May 2009 Posts 341 Thermalright ultra 120 with two noctua p12 fans or phase change cooling Last edited: 5 Jun 2009
5 Jun 2009 at 21:55 #3 Monkeynut Monkeynut Soldato OP Joined 7 Nov 2007 Posts 6,858 Location Required Would it help to replace the stock case fans at all?
5 Jun 2009 at 22:01 #4 user1453 user1453 Associate Joined 18 May 2009 Posts 341 possibly, are the stock fans not up to much?
5 Jun 2009 at 22:52 #5 Audigex Audigex Associate Joined 3 Feb 2009 Posts 2,245 Arctic Cooling Freezer 64 Pro. TRUE/Noctua/Titan Fenrir, you'll likely lose 10c or more What are the cables like in your case? And replacing the stock fans likely won't do any harm
7 Jun 2009 at 01:34 #6 Monkeynut Monkeynut Soldato OP Joined 7 Nov 2007 Posts 6,858 Location Required user1453 said: possibly, are the stock fans not up to much? Click to expand... They're rather noisy. The wiring's kinda messy inside too. I haven't had chance to tidy it all up yet. Any other ideas?
