Help me setup 2 public IPs on our firewall
Man of Honour
17 Oct 2002
Retired Don
Hi guys,
We have a Sonicwall TZ180 firewall, and 2 public IPs provided by our internet service.
So far we've been using one public IP, which is the WAN IP on the firewall, and we have some access rules setup for port forwarding.
We now have a need to run 2 websites on port 443 on 2 different virtual servers, so we need to use the 2nd public IP that we have, but I have no idea how to configure this on the firewall.
Any help would be great!
Just been doing some more reading, will I need to put a switch in between the WAN switch and the Firewall, and plug the server requiring the 2nd public IP directly into in with the public IP as its static IP, with the rest plugged into the firewall?
Thanks,
Mal
If I understand right,
you have a no nat WAN router than connects to a firewall,
you need to plug the WAN router into a switch,
then simply plug the firewall into the switch, and the new box...
you can always user host headers to have several web sites on the same port on the same box.
(you tell the web server that www.a.com goes to web site 1, and www.b.com goes to web site 2)
Thanks for that.
I was considering host headers, but this is for https port 443 sites, so I don't think that will work easily!
Cheers,
Mal
I admit i only took 30s and only half read the article but..
http://www.microsoft.com/technet/pr...108-b1a7-494d-885d-f8941b07554c.mspx?mfr=true
You can configure Web sites that use host headers to serve protected content over a Secure Sockets Layer (SSL) connection, that is, a connection that uses https:// instead of http://. To use SSL with host headers, you must obtain and install a wildcard server certificate. After you configure SSL host headers for a Web site, protected content is served only over an https:// connection.
Which version of SonicOS is the TZ running - Standard or Enhanced?
That makes a big difference in setting up the port foward. Everything can stay behind the SonicWall.
One-to-One NAT is then. From the web GUI:
Network > One-to-One NAT
Enable it and add your new server with the relevant internal and public IPs (public will be the second one you have off your ISP). Note there's no need to "declare" this IP on the interface section.
Then in Firewall > Access Rules
Create a new rule to allow HTTPS from * (or just WAN) through to the LAN with the private IP of your new server
There's some screen shots based on SonicOS Standard 2.0 on page 6 onwards here (PDF).
HTH,
Chris.
One question - If I create a new rule for HTTPS from * to 192.168.1.11, will this not conflict to the existing HTTPS rule I have from * to 192.168.1.13?
Not a problem, the NAT engine in the firewall will look after the translation and direct traffic accordingly.
As an example...
Say your internal servers with the HTTPS site were 192.168.10.11 and .12. You could have two rules to allow HTTPS from the WAN to each IP. Or, you can have a single rule to allow HTTPS with the destination as the range 192.168.10.11-12.
I've found an extra bit of documentation:
You have three web servers on the LAN with the IP addresses of 192.168.1.10, 192.168.1.11, and 192.168.1.12. Each of the servers must have a default gateway pointing to 192.168.1.1, the SonicWALL security appliance LAN IP address.
You also have three additional IP addresses from your ISP, 208.1.2.4, 208.1.2.5, and 208.1.2.6, that you want to use for three additional web servers. Use the following steps to configure One-to-One NAT:
1 Select Enable One-to-One NAT.
2 Click Add. The Add NAT Entry window is displayed
3 Enter in the IP address, 192.168.1.10, in the Private Range Begin field.
4 Enter in the IP address, 208.1.2.4, in the Public Range Begin field.
5 Enter in 3 in the Range Length field.
For the firewall rule:
Configure the following settings:
• Allow
• Service - HTTP (or HTTPS)
• Source - WAN
• Destination - LAN 192.168.1.10 - 192.168.1.12
