I've got an Akasa Omega case which has the following fan slots:
1x 120mm front
2x 120mm side panel
1x 120mm rear
2x 120mm topcase
At the moment I have 2 fans running very slow pushing air out the top of the case and 1 running very slow into the front of the case.
However it is causing a lot of dust inside my case so the static pressure is probably all to pot.
I've got a h50 with 2 of the standard corsair fans in push pull - pushing out the back of the case but its probably not doing much good as the rad is so dusty!
Can anyone recommend me a way to get it all nice and quiet as the h50 seems to be kicking out a lot of noise.
Also whats the deal with retro fitting passive cooling to a 260gtx?
And whats the deal with replacing PSU fans please?
Many thanks!
1x 120mm front
2x 120mm side panel
1x 120mm rear
2x 120mm topcase
Many thanks!
