Hi guys and gals!
Been tinkering with the idea of doing an upgrade for myself, since a friend suggested that they would be interested in the parts I would upgrade, i.e. Mobo, CPU, PSU and memory. I already have a spare GPU, HDD and DVD/CD ROM Drive to add to it.
Now I don't really need to upgrade, should probably try and save my money instead so I am looking into what a low budget spec would look like for them. As mentioned I have some parts already so basically all that is needed is a Mobo, CPU, PSU and a case to fit it in, since the case they have is very old, i.e. a old IBM case, so would think a new case would be better of for them!
What I have come up with is this so far:
Intel E5300 £52.99 http://www.overclockers.co.uk/showproduct.php?prodid=CP-273-IN
Corsair CX 400W ATX £39.99 http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-CS
Gigabyte GA-943-ES3G £59.98 http://www.overclockers.co.uk/showproduct.php?prodid=MB-217-GI (Picked this because I am not sure if they want to go 64Bit in the future so at least they have more then 4GB RAm if they want to then)
So far, that would total up to £152.96. If this can be brought down further that would be appreciated. Their current machine is a AMD so if anyone has any idea of what to pick for going the AMD route, please fell free to spec away!
Now, question is what case. I am pretty sure they would be happy with any case since they not really into looks, just as long as everything fits inside it and the PC runs as it should then they are happy. Personally though, I prefer that the PSU is at the bottom, but looking through OcUK's cases I can't seem to find one in the lower price range, first one I could find is the Antec 300 Gaming case, for £39.99 http://www.overclockers.co.uk/showproduct.php?prodid=CA-101-AN&groupid=701&catid=7&subcat= Which would put the price up to £192.95. Does anyone know of a cheaper case with the PSU at the bottom? Actually, what I will do is ask them what kind of case they want and how much they are willing to spend on one and then go from there, but please fell free to suggest cases that are good but "cheapish".
Also, would the above PSU be enough for that CPU and either a 7900GTX, 8600GTS or a 8800GTX? I haven't asked them which one they would prefer yet. They are not into heavy gaming, just older games such as Port Royale 2, Thiefs 1 & 2, Sparta/Troy, Total War series, AoE III <--- that is probably the most modern game they have I think.
Any other suggestions or advice to bring down the costs are greatly appreciated.
