Hi guys. I'm looking at trying to wittle down some components to build a cheap HTPC. Although I'd like it as cheap as possible, I don't really have a budget in mind, but I'd like it to meet some criteria:-
* As small a motherboard as possible, so I can fit it into a small case such as a shuttle
* A GPU with Hardware HD acceleration
* As silent as possible, i.e passively cooled GPU, aftermarket CPU cooler, silent PSU
* Decent onboard sound, i.e DTS, optical out
So basically I'm looking at building something that will handle HD video encodes, with the potential to play Blu-Ray and HD-DVD at some point in the future.
One thing I'm not sure about is HDCP. Is this something I need to consider in the build? What are the implications of this? I'll be using a DVI->HDMI cable to connect the PC up to the TV.
Cheers guys.
Cheers guys.
